I’m having major framing issues. I’m new to this so I’m still learning.Ive Tried Everything
I am having issues when it comes to framing. Every time I I click farm the lazer shoots to the right side of the frame, gets stuck and start make a noise
Highly recommended reading :wink:
In addition to @bernd.dk’s suggestion:
  • The machine must home correctly when you turn it on
  • Never shove the laser head around by hand
If it’s that laser, then it’s not obvious it has homing switches. If it doesn’t, then you must always turn it on with the laser head in the front left corner so the controller knows where it is:
Also, verify the sizes & speeds they mention in the Quick Start Guide for LightBurn:
One more suggestion: Use Absolute Coords as your Start From: choice in the Laser window. When you do, your design can be imagined as looking straight down at where the laser will go. This will help you avoid Out of Bounds errors.
