Hi friends,
I have a problem with the material cutting settings. I have a new Vevor CO2 130W. RUIDA controller. Bad cut at a speed of 22 mms/sec.
I don’t have a smooth cut. Why?
Looks to me like you have a loose belt or set screw. Check your attachments and your slide rails for any sticky spots.
Also try to Slow down the speed by 10% - see if that helps smooth out the movement.
