I need to set up my elegoo to wifi without any add on purchases
i need to set up my elegoo to wifi without any add on purchases
Does your Elegoo controller board support WIFI?
Why WIFI? That is the least reliable method you can use.
yes but i can’t get lightburn to see it. how do i find out if my computer will support wifi?
What do you mean you can’t get LightBurn to see it?
Have you set up a GRBL profile? Have you selected the correct COM port?
Do you see any activity at all in the console window when you turn on your machine?
i am new to this and i don’t know about com ports or anything else in lightburn. I just wanted to set up a wifi connection on my desktop. Then I tried it with my Laptop which certainly has wifi and it still didn’t work. i was able to load the GRBL profile but is still would not connect.
i have to put the lazer about 20 feet away from the computer because i have no room for it near the computer and i don’t want to use a long cable.
I did a little playing around with the Wi-fi on the Phedca. I Was never able to connect it to my local network. I’m not sure if that’s just because I received a very early manufacturer demo model.
By all means you can go ahead and try.
