hello.I am a begginer and I don t now how to cut a piece of plywood.I can only engrave.What I should do?
If you are a beginner i sugest you to read some Docs
If you intend to cut plywood first of all you need to select in “Cuts/Layers” window mode
- line
Then adjust settings according the plywood thickness.
A small air compressor will help.
Air assist improves cutting greatly.
