Ik heb in lightburn settings aangevinkt: vereist kaderen alvorens starten, maar mijn kader word niet op mijn werkstuk getoont
Ik heb in lightburn settings aangevinkt: “vereist kaderen alvorens starten”, maar mijn kader word niet op mijn werkstuk getoond maar kan wel starten en graveren, maar kan niet zien waar ik exact ga graveren
>I checked “require frame before start” in Lightburn settings, but my frame is not shown on my workpiece. I can start and engrave, but I cannot see exactly where I am going to engrave.
When you created the device profile for your laser did you import the manufacturer’s settings as described in our documentation?
Your galvo framing window should open up presenting different framing styles:
We need details on the framing settings you are using and the project file you are attempting to frame.
Here’s where you can learn more on the red dot used for framing: Device Settings: Galvo and Basic Settings - LightBurn User Guide
Selecteer je project en kies Kader in het menu rechts.
Select your project and choose Frame from the menu on the right.
Hi <
i got it working again , by re installing lightburn
Provblem solved by re intalling Lightburn
