Hello LightBurn Support,
I am experiencing an issue with the red crosshair positioning light on my iKier K1 Pro 24W laser when using the Frame function in LightBurn.
Machine and software:
Laser: iKier K1 Pro 24W
LightBurn: Core 2.2.00
Also tested with LightBurn 1.7
Controller: GRBL 1.1h, iKier firmware
Firmware identification:
[VER:1.1h.20230501:] -
Laser mode:
$32=1 -
S-value max:
$30=1000
Problem:
When I press Frame, the red crosshair positioning light turns off during the framing movement and comes back on when the movement finishes.
This happens with both rectangular framing and outline framing.
However, when I move the laser using the Move panel arrow buttons, the red crosshair stays on throughout the movement.
The Laser On When Framing option is disabled. I do not want to enable the main cutting laser during framing.
Tests performed:
Framing with my original GRBL device profile: the red crosshair turns off.
Framing with a newly created GRBL device profile: same problem.
Framing in LightBurn 1.7: the crosshair turns off immediately in both framing modes.
Moving the laser using the Move panel: the crosshair stays on.
Running the following G-code file through Run GCode:
G21
G91
G1 X100 Y0 F6000 S0
M2
Result: The red crosshair stays on throughout the movement.
- Running the same file without
M2:
G21
G91
G1 X100 Y0 F6000 S0
Result: The red crosshair turns off during the movement.
This result is repeatable and suggests that the presence of M2 in the streamed program affects the crosshair behavior.
G-code sent by Frame in LightBurn 2.2.00:
G00 G17 G40 G21 G54
G91
G1 X75Y0S0F6000
G1 Y-65
G1 X-75
G1 Y65
G0
G90
There is no M2 at the end.
G-code sent by rectangular Frame in LightBurn 1.7:
G00 G17 G40 G21 G54
G91
G0 X0Y-91
G1 X100S0F6000
G1 Y91
G1 X-100
G1 Y-91
G0 Y91
G90
Again, there is no M2.
My questions:
Is this a known compatibility issue between LightBurn framing and iKier’s customized GRBL firmware?
Is there a way to make the standard Frame button send an
M2at the end of the framing program? -
Is there another supported way to keep the red crosshair illuminated throughout framing without activating the main cutting laser?
Could this behavior be addressed in a future LightBurn update?
I would strongly prefer to keep using the normal Frame button rather than running a separate G-code file for every job.
Thank you for your help!
