Having problems with the Ikier Master. The thinking this may be Lightburn associated.
1)I am getting a stoppage during engrave and get a message that The movement Exceeds Software Limits. Not sure if this is a Lightburn situation or the Master.
2)Doing a Material Test with Lightburn, I am getting the outer text and all but instead of getting test blocks showing results, I am just getting small straight lines. Ikier support says this is a Lightburn question.
You need to check the material settings within this dialog. It’s hard to tell without a picture, but most likely your line width / LPI setting is incorrect. Try using a line spacing of 0.1mm as a starting point.
