iKier Ultra recognizing first time
When will Lightburn support recognizing the iKier Ultra 36w laser machine during the setup process, so the correct options are configured?
GRBL machines are typically detected correctly but others have reported issues with detection. Fortunately, there’s not much to the setup.
You can follow this. Make sure to pick the correct work area for your machine if this is different from the one in the link.
It’s not the task of LightBurn to provide profiles for any of the millions of laser types out there. If a company sells a laser with “LightBurn compatible” logo or statement, they should provide the required information (or config file) to you.
