When opening/importing an AI file, Lighburn shows 3 or more different line paths.
I’ve tried exporting different versions of AI and SVG with same results.
Am I importing incorrectly?
Thanks-
Jason
Thanks-
Jason
This typically happens when the art has been generated with line weight/width or stroke/fill to the path. For laser work, don’t do that. If you draw a circle and set the line width to say 10px, you have really created 2 paths, one circle10 px smaller, inside the other.
If you view this art in AI as a wireframe you’ll see the same effect you see in LightBurn.
Thanks. That was it. I thought I had removed the fill, but, guess not.
Thank again-
Jason
