I’m trying to use Lightburn as it seems to do much more than the xtool software. It does the framing, but when I set it to start the job, it makes all of the motions, but doesn’t leave a mark. Nothing. It does work with my xtool software so it has to be a setting I’m missing. Any help appreciated.
Slow down dramatically.
Check that you are using mm/min and not mm/sec and going too fast.
Thank you both so much for your answers. I figured it out yesterday. I had to upload the settings from x tool and I hadn’t done that. I had just used the automatic settings. Thank you again.
I am having the same issues how did you fix it?
