I ended up buying the Omtech 60W. That’s a damn good price and I’ve heard a lot of good about Cloudray. Ultimately, it depends on your budget. There’s no disadvantage to going with the 50W over the 30W that I’ve found aside from price. I think both will be great for what you’re doing. I went 60W simple because I wanted more speed and I’m planning on deep engraves for suppressors, doing serial numbers but I tend to overkill everything. I probably should have gone with a Stinger I but I’m glad I have the III.
You know it’s like when you ask a person. Ford or Chevy. I know both will get me back to work and back. Both have radios, etc… But when it comes to the engine and those details, one “might” be worth the extra money over the other.
I do remember seeing a video about the laser source from Laser Everything. He talked about JPT, Raycus, etc… I’ll have to look at that again.
I don’t want to get deep in the weeds on it, because it will just confuse me. It’s always about how much $$$$ you have to blow. Isn’t it?
IMHO, I’d go for a lower wattage source with the ability to do annealing.
You can mark anything metal with an annealing process and it doesn’t change or damage the metal. This is used for surgical instruments as it doesn’t leave any areas that can have deposits.
The Raycus is not the most dependable as you can see in the video. A lot of what I do can’t be done on the machine you are intending to purchase.
A 30W will take longer, but will do as good a job in the end.
I think a good trade would be to spend a bit more in control ability and lose the higher wattage.
Almost all the posted photo in this thread are annealing not engraving.
Hi Jack. So 30w over the 50? Meaning 30w is lower than 50w. Right? I don’t want to just throw money out there cuz I can to a point. I like that I can get 2 lenses and a rotary in this package from them.
Remember. I’m really just trying to increase efficiency in tumblers, keychains, and possibly cork [snicker-snicker], and have some type of backup machine if my CO2 decides to take hike off the cliff.
If I can engrave metal and open another revenue stream, then that’s just gravy for me in my mind.
Thanks man.
Classic example. I’ve got 4 square coasters in a jig, and the fastest I can mark and keep the quality is 10 minutes. I’ve changed settings in the layer under grouping, and one was 14 minutes, one was 29, and the fastest is 10 minutes…
30W may take a number of extra passes. I think the tradeoff would make you more happy in the end.
I’m just suggesting that you might want to anneal metal with a black mark for knives, can openers, tools and many other things.
This is one of the brass coins from Amazon, I lased the area around the cat, but did an annealing to make it black… can’t anneal then doing this probably won’t be possible…
It’s your money, I’m just trying to pass what I have learned… Main reason I got the JPT M7 model, was annealing without having to damage the material… My knives are marked… need to anneal to avoid damaging the knife…
I sincerely doubt that a 30W wouldn’t be as fast as a 50W for tumblers. You can anneal stainless tumblers without coatings… more types you can use/sell
You can theoretically do plastic mugs/cups with the jpt, like the plastic magazines for firearms.
BTW Jack and others… They offer 2 lenses in the deal. If I have “any” leverage, what lenses would you recommend. Especially for tumblers. 300mm? I’m not sure how tall the tower is. Maybe 500mm. Got to get the specs to see exactly what I’m going to get.
Lens size is not coverage size… my F420mm is for 300x300mm coverage. My F100mm is 70x70mm. Need to be specific… I tend to use the manufacturers numbers… F420mm for the 300x300mm coverage.
My column is about 80cm… if you’re going to get a F420 for 300x300mm coverage, it has to come with a relatively tall column. Make sure to check… My F420 is about half way up… Haven’t tried my Piburn on it yet…
Figure out what size you need to cover and pick the 2nd lens for that.
A little larger is better… the longer the lens the more power you will need and the larger the dot…
I would recommend a CO2 galvo style laser with a rotary attachment. The engraving speed of the galvo lasers are much faster than the gantry style laser. CO2 in this situation is will be much more productive that a Fiber laser.
Dav, I’m basically looking for two things. A backup solution to anodized aluminum, slate coasters, and tumblers. Plus improved efficiency with my time while in the shack.
Yeah, I’m not going to put money in on another CO2. Longer life with Fiber, Engraving metal a plus.
Probably going to order one really soon. Still trying to educate myself on the pro’s and con’s. I figure I’m over thinking it, but 4K is a chuck of coin.
If I’m not mistaken, and good chance I am, I believe JPT source has a broader freq range than Raycus, per Laser Everything Video Guy.
To be honest starting out last year, I never even thought about a 2nd machine, but I’m paranoid about not having a backup. It may take me 6 months to figure out how to use the freak’n thing.
I figure Speed, Pwr, and Frequency is all I have to worry about. Tiff Tiff…
