Image Adjust - Invert Image NOT saving
Happens on 1.701 and 1.7
Maybe me, maybe not - Yet to roll back to 1.603
If I import an Image and select Image Adjust and then Negative or Image reverse - it looks Good, but select OK and NO CHANGE - Importage image is same same.
I did ten to use this feature - but no longer works. Other adjustments are saved and updated , but Not if either of the option to invert the image.
It does not display inverted in the work area, but go to the preview showing how it will burn and ensure the invert checkbox is off and it shows that it will burn inverted.
Without processing.
Adjust Image, select negative image.
I don’t know why it doesn’t display as negative, but it does appear to output correctly. I’m not at a laser to test it.
