Image appears upside down when previewed
All of the sudden, all my images appear upside down when I view them in preview mode. If I reset my device setting to the top-left instead of the bottom-left, they simply reverse. Before today, an image looked the same in both the work area and when I previewed it.
Change it to the top and it should flip vertically along the Y axes.
It will mirror across the perpendicular axes.
Generally these machines have one home corner. This determines the machines operating quadrant. If you change quadrants, you change how the art is oriented relative to a change in quadrants.
It looks like you have Rotary enabled as well as mirror output. Disable one or both of these.
Thank you. That solved the problem.
