Every image I import or type in for my fiber laser to engrave rotates 90 degrees when it comes time to engrave it. it shows on my screen the proper way, and even on the image preview it shows up proper, but as soon as I go to fire the laser its rotated. I can obviously rotate my image 90 degrees every time but I don’t have this issue on my CO2 laser.
The origin is set wrong somewhere, Lightburn and the machine(s) have to match…
Is the origin in Device Setup the same for both machines ?
Are the home positions of the machines the same?
I believe you have the Wrong Galvo select for your X Axis. In Edit/Device Settings, try switching which Galvo is X. Mess around with these settings until it burns correctly:
