I just tried to capture a image and seperate it from background cant seem to get it.i trace ungroop select all and delete but background stays and I cant select the image I want to capture
If the background image is from the camera, then it’s not a thing you can select and delete. In the Camera Control window, after you trace, click here:
Turning off ‘Show’ will hide the camera capture.
And if you ‘select all and delete’ you’re deleting everything.
Ok that works but cant capture or copy a object with a lot of detail the threshold wont let me other than that it works fine
The shadows there are going to cause you issues. You’d need to have very even overhead light to get a good capture from a shape like that because of the thickness.
I will try better light thanks
