Image inverted and rotated
I’m in the process of setting up my new laser (ComMarker 50w with windows 10). All my images are mirrored and rotated clock wise 90 degrees. I’ve been searching the controls and youtube looking for the control to change it but haven’t found it yet. Does anyone know how to fix this?
Did you import your markcfg7 file during the setup of your device? This should have all the data as to the galvo config so that your output is oriented correctly. If not, you can go back through the device add wizard in “Edit” mode and import that file.
If you don’t have it, you need to go into Edit/Device Settings and play with the Galvo config to flip things the correct way:
I do have that. I’ll check it out to see if it fixes the problem. Thanks
