New to using lightburn. I was doing great, but now my images are engraving backwards. Happened from one day to the next. My origin is still set as I initially had set it up. What could have happened?
There are two origins… the one in the software that commonly causes this is in Device Settings. This origin usually causes the issue… double check that setting
Did you accidentally invert the images?
I checked that, but no. Image displays correctly on in lightburn
My origin is set correctly, don’t know
what else to do. Any other ideas. I switched the origin to every corner, but it flips the image in lightburn
If you change the Device Origin with a project loaded, it will flip the image around as the image is oriented from the origin. Set your origin correctly, THEN load your project.
