Hi. I nedd an advice which made mode will be the best to engraving this type of vector image link below ? It is black and white graphic. I want to engrave it on plywood. What parameters do you suggest will be the best ? https://i.etsystatic.com/18808682/r/il/f5850d/1737260845/il_1588xN.1737260845_jse2.jpg
For pure black & white images like this, Threshold is usually the best choice for the image mode.
Thanks for reply. What about “overscanning” ? it set default for 2,5 % . Is it ok ?
Try a small test to find out. If the edges are too dark, then you would need to increase it, but 2.5% is chosen as a reasonable default.
