Why would an image show on the work space but not in the preview and no burn?
Thanks, Duane
I show the same. May have to do them separate.
Tried that with no joy. I also opened a new file and imported it and when I go to preview the screen is black if I invert the image then screen is solid white. Going to go online and download a different file and see what happens.
Try this please
Edit → Select all
Edit _> delete duplicates
Did LightBurn find any duplicated?
If you have 2 overlapping shapes of the same exact size and shape, they will “cancel” each other out
No duplicates shape. I opened a new file with just the heart and in preview the screen was solid black and if I inverted the image preview showed a solid white screen.
Any chance you could save that file and upload it here so we can take a look please?
TEST SCROLL.lbrn2 (332.7 KB)
Hope this came through okay.
The problem seems to be primarily that you have it set to Negative
So a black heart, in the negative will be a white heart. Therefore, no engrave
I think pass-through should also be disabled
Ok, I’ll try that. And didn’t see I had it set to pass through. Let you know what happens.
That fixed It!!! Damn your good!!!
