OK, so I’ve got an image saved as .png file.
If I import it into LB and set up some cut parameters and then have a look in the cut preview window it looks just fine.
But if I rotate that image 90 degrees in LB then preview, part of it gets cut off.
If I rotate in Inkscape first then import to LB it’s fine.
Uhhh… what’s up with that?
Obviously the work around for me is to rotate the image first, so it’s not a big deal.
LB 0.9.02.
The .png was created in Inkscape. (0.92.4)
Win7 machine.
