Image Trace Cut is hindered when scaling down an image
I have traced a descent sized image in terms of L x W, so that the Trace Image feature can grab as much detail as it can.
When scaling down the traced image, part of the trace disappears and there is a disconnect which can only be seen in the preview tab.
Image preview when making the trace bigger and there is no disconnect:
How can I make sure the scaling down is not butchering the image trace?
Somehow, this was not happening yesterday. I even have test pieces which were cut out just fine…
Can you upload the .lbrn file for review?
objects.lbrn2 (99.9 KB)
Attached is the file @berainlb
In Optimization Settings, disable “Remove overlapping lines” or make the value much smaller. Your current setting is conflating the lines as overlap at the scale you’re trying to burn.
OMG! I forgot about this. I was working on something new and forgot about the setting.
Thank you so much!
