Images are squished when using rotary
I have done the rotary setup and found my steps per mm and the tumblers were coming out fine. Then a couple weeks ago the images starting being squished. All my settings are the same and my setup is the same. When I do a test of a rectangle to measure it, it measures right. But when I burn any image it is squished. I have started stretching the image by 30% to get it to look right but I cannot figure out what changed. Thanks for all the help.
is it possible the rollers have become dirty and are slipping?
I have cleaned the rollers. Last night I made a tumbler that turned out fine and I put another one on and hit start and it came out squished
I decided to clean the whole thing and that fixed it thank you.
