Just purcahed an X Tool D1 Pro, 20 W laser. Want to use LightBurn, however, when I try to print text, it comes out inverted and reversed. I have no idea what to do. When I run the XCS software, everthing is fine. So I think my assembly process was OK. Any help would be greatly appreciated. Thanks, Dan
Hi Dan… welcome to the forum.
It’s likely that you have Edit → Device Settings → Origin set incorrect. Most of these are the front left, but I have no idea about yours.
Did you follow any kind of procedure to install Lightburn?
Hey Jack, Thank you for your quick response . I did see a reference about changing the Origin setting. I tried that ( I think) and nothing changed. I will to uninstall and reinstall Lightburn and find a prodcedure to follow. I’m pretty sure I just jumped right in.
Shouldn’t need to reinstall everything… just follow the procedures for setup.
I think it’s outlined in the xTool documentation…
This is just settings… nothing more
