Images do not burn square on the workpiece
When engraving an image, the image does not engrave square. I have tried several images and can not get any too run true 90 degree corners. Single pass and Mac ios
Adding a photo of your issue would be very helpful. Can you also supply us with the make of the laser machine you are using. The more information you can give us helps us understand the problem.
