What is the best way to import files created with the free version of Fusion 360? I don’t see a direct match!
This post is relevant:
All of the file types that are not greyed out in that list are for 3D geometry and LightBurn doesn’t work with 3D. Whenever I use Fusion 360 to create objects (such as birch ply boxes) to be cut in LightBurn I model the box (for instance) then create a drawing from that model with all of the views I want to cut. Then I export the drawing as PDF or DXF and import that into LB.
Here’s an example:
Hope that helps.
Thanks @berainlb and @Marcus_Wakefield for your tips, we will try them out!
