Hi
Is there a possibility to import gcode into Galvo Files?
I would like to use a different slizer for deep laser engraving
THanks for the feedback
Hi
You can import gcode into LightBurn. It will basically reproduce the laser-on path defined in the g-code.
However, the g-code you import is likely to be quite different from the original geometry used to generate the g-code. For example, shapes will not be closed, filled shapes will become a series of tightly spaced lines rather than a closed outline, arcs will become straight approximations, etc.
Although you can import G-Code geometry into a LightBurn design, the Ruida controller uses a proprietary command set and does not accept G-Code commands.
LightBurn must convert the geometry & layer settings into the Ruida command set, then send that binary data to the controller.
As a result, you can’t send G-Code files created by another slicer directly to a Ruida controller.
A GitHub repo lists (some of) the Ruida commands:
Thanks
But Galvo laser don’t work with ruida controllers. Does this work with EZCad2 controllers the same?
The ability to import is unrelated to the laser being output to.
I misread your profile and thought the Ruida controller was running the Fiber laser.
