That’s what I thought as well.
Can anyone else confirm this?
Is there an other way to replace image elements dynamically?
I have a template with text variables to replace with csv data. That part works already.
But also, I need to replace placeholder images with pictograms.
I did this with Inksape/NextGenerator but the replaced images don’t show up in Lightburn.
And I dont want to replace it manually, because there hundreds of them, if not thousands.
I would be grateful for any advice.
Yes, open that external image directly. But that’s not what I need in this case.
Ok, that gives us a better idea of your intentions and could help find a solution. I’m not familiar with NextGenerator but I’ve just had a quick look at it. I might be miles off here but rather than using it to insert a link to a file could you use it instead to insert just the geometry definition for each image/pictogram? Is that a possibility or does this fall down somewhere along the line.
