Importing a DXF to use as my frame shape?
I am new to the laser world and wanted to see how I could import a DXF file that is the shape of the object I am wanting to engrave and apply my image within that shape and using the DXF as my “Frame”
You can use the DFX shape as the base for a “mask” to be applied over your image.
After you import your DXF, you can set that outline as a T1 or T2 layer (tool layer). Items on that layer only exist for layout purposes.
You could then use that shape to do image masking, if required: Image Masking - LightBurn Documentation
