Can anyone help with importing bundle to second pc i can drag the file into lightburn due to the licence agreement info (your trial period has expired) flag being present. i have a licence on the pc i am trying to import frpm
Sorry should read cant drag
I think the bundle files are saved as a .lbzip file on your pc to wherever you chose.
Be worth doing a search to see if you can locate it
…that is correct, and they need to be imported, then they will be automatically unpacked and inserted in the correct places.
You mean, one of the PCs doesn’t have a license and you want to interact with it? That doesn’t work. But you can assign your license to three devices in parallel. So you can assign a license to the blocked LB, and then remove the license afterward.
