I design in Illustrator and import into LB for cutting as I find it easier. However, fonts used in Illustrator do not open in LB, any idea how to overcome this? It would be nice to be able to import with the font so I can change on the fly in LB.
Can you confirm you’re working on the same computer for both programs?
Is it that the text holds but the font selection does not? Can’t quite recall how font handling from Illustrator is handled.
I do know that fonts are retained in SVG format. You may want to try saving in SVG format to see if fonts are retained that way. Make sure to set DPI for SVG to 72 DPI under Settings in that case since I believe Illustrator saves at 72 DPI instead of 96 DPI “standard”.
