Importing drawings with wrong size
I have used Lightburn for sometime now, first with my diode laser and now with my CO2 K40 and I have encounter a few issues with LB. This time is when importing files, either AI, SVG, or simply pasting from the clipboard.
Sometimes, when I import files, LB import these but in a slightly smaller size. Most of the time the importing is accurate, but once in a while LB uses this smaller size version of the drawing. Often it is not easy to notice the different size unless I check the dimensions before sending it to the laser. Other times I realize of this issue after I get finished engraving or cutting my project, and I have to start over.
I have tried to find out why this is happening. I normally create or modify designs in Illustrator and verify the dimensions there. When I create or resize in LB, there is not issue
Check your SVG import settings.
Thank you Tim,
I had the import settings set to Inkscape (96 DPI) as default. I hope that’ll fix my issues
