Importing DXF wrong
Hey all!
Not sure what I’m doing but every time I import a dxf into light burn it only loads in a red dashed line circle. the length and width is like 780" and when i drop it down then it shows the circles. I’ve checked the file with a dxf viewer and it looks good there
Check the units you are exporting in - If LightBurn is set in mm, and you export in INCHES, there could be a problem.
thought about that and the file that i bought also has mm and same thing
