MGE
(JOSE)
September 5, 2024, 10:51am
22
Hello
Consulting in the forum about error 3, I have applied a solution regarding the power of the USB, through the battery:
How to disable Windows 10’s ‘USB selective suspend’ setting | Windows Central
Subsequently, apparently error 3 has disappeared, but now when it turns on it indicates a new error, 8.
I’m attaching the $$ commands again so you can review.
Thank you very much for your attention.
Esperando la conexión…
�iF:ok
ok
[VER:1.1h.20230903:]
[OPT:V,15,128]
Target buffer size found
ok
Inicio
ALARM:8
Error de inicio. El ciclo no pudo borrar el interruptor de límite al extraer. Intente aumentar el ajuste de extracción o verifique el cableado.
ok
Grbl 1.1h [‘$’ for help]
[MSG:‘$H’|‘$X’ to unlock]
ok
$0=10
$1=25
$2=0
$3=4
$4=0
$5=0
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=2.000
$30=1000.000
$31=0.000
$32=1
$41=0.000
$40=0.000
$100=80.000
$101=80.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=900.000
$131=900.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
MikeyH
(Mike Hembrey)
September 5, 2024, 3:33pm
23
MGE:
$27=2.000
Change this one to $27=3 using the Console window. If that does not help, try $27=5 instead. Let us know if this solves the problem.
You did not answer this question. Does it?
MGE:
$22=1
This says you have enabled HOME, which means you have limit switches. Does it Home okay after fixing the $27 parameter?
Before you try running a program, you MUST make sure the parameters related to motion are set up correctly. That is why the last two questions.
MGE
(JOSE)
September 6, 2024, 11:00am
24
Hello!
I have made the change to the parameter $27=3 and $27=5 and the error continues. The procedure I perform is to start the machine and asthmatically it is positioned at point 0. Then I export the dxf file and enter cutting parameters. Then you press “frame” to check the path and it gives error 3 as it collides with the frame. I can manually place the laser in the center and make the cut, but it is not the correct procedure.
On the axis shift using the arrows in the “motion” interface if it responds to clicking the buttons, all of them. It is moved correctly.
Regarding the parameter $22=1 is already modified from before. I attach console parameters.
ok
[OPT:V,15,128]
ok
Inicio
ok
Archivo importado en 8 milisegundos
<Idle|MPos:1.000,1.000,0.000|FS:0,0|WCO:0.000,0.000,0.000>
ok
<Idle|MPos:1.000,1.000,0.000|FS:0,0|Ov:100,100,100>
ok
Corriente de inicio
Trabajo detenido
Secuencia completada en 0:00
ALARM:3
Restablecimiento estando en movimiento. Grbl no puede garantizar la posición. Es probable que se pierdan pasos. Se recomienda encarecidamente la reubicación.
ok
ok
$0=10
$1=25
$2=0
$3=4
$4=0
$5=1
$6=0
$10=1
$11=0.010
$12=0.002
$13=0
$20=0
$21=0
$22=1
$23=7
$24=200.000
$25=3000.000
$26=250.000
$27=3.000
$30=1000.000
$31=0.000
$32=1
$41=0.000
$40=0.000
$100=80.000
$101=80.000
$102=250.000
$103=100.000
$104=100.000
$105=100.000
$110=6000.000
$111=6000.000
$112=1000.000
$113=1000.000
$114=1000.000
$115=1000.000
$120=1000.000
$121=1000.000
$122=1000.000
$123=200.000
$124=200.000
$125=200.000
$130=900.000
$131=900.000
$132=200.000
$133=300.000
$134=300.000
$135=300.000
ok
Thank you and best regards.
MikeyH
(Mike Hembrey)
September 6, 2024, 2:53pm
25
We need to keep the errors and alarms separate. Are you still getting the Alarm 8 message?
Make the changes in the following image. Use Absolute Coords for nearly everything. Your machine has Home switches which makes this easy.
MGE:
Does it agree with this image?
With these suggested changes, you should be able to Frame okay. Please let us know your results.
system
(system)
Closed
October 6, 2024, 2:54pm
26
