In Gcode added line G0 Z10 with version 0.9.24
Hi,
with upgrade from 0.9.22 to 0.9.24 one of the noticeable changes is added row G0 Z10. Where can be this set to 0 or how to disable this additional line?
For me this is not working due to I’m laser in graving from user origin and do not need additional Z movement.
I see usability if I can set this value to focus length. In this case, I can set user origin at the surface of the object.
BR
Roman
In Edit > Device Settings you will have Z moves enabled.
You can turn that off, or you can set ‘Relative Z moves only’, which will only move relative from your starting height.
Or, the ‘Material (mm)’ value on the main window panel, just below the Cuts/Layers window will control the initial Z move height.
Hi,
I have figured out. I see that I have missed this. Thanks
