Incompatibilité avec Atomstack S 20 pro?
Bonjour, nouveau sur le forum, je viens d’acquerir le graveur mentionné, installation de L Burn, GRBL declaré, commandes manuelles pour le deplacement ok, mais essai de gravure ou autre zéro…
les jours passsent, l"essai de L Burn s’effiloche sans que je puisse le tester, et je n’ai pas de solution trouvée a ce jour… moche moche …
Hello, new to the forum, I have just acquired the burner mentioned, installation of L Burn, GRBL declared, manual controls for displacement ok, but burning test or other zero…
the days pass, the test of L Burn frays without me being able to test it, and I have not found a solution to date… ugly ugly…
If you can show the settings you are attempting to use, that would help.
Does the laser turn on but not burn, or does the laser not turn on at all? If you are having problems in both LightBurn and LaserGRBL, it is possible that you have a physical issue with the machine, like a wire that is disconnected, or the machine could be out of focus.
More information about what is happening would be helpful.
bonjour et merci pour votre réponse rapide, finalement j’ai reussi à trouver…
je joint une photo qui explique mon erreur… par manque de connaissance du logiciel j’ai mal interpreté certains parametres…
par contre, je ne trouve pas pour joindre la photo… :shushing_face:
I have increased your user level here on the forum so you should be able to post a picture now.
