Hello,
I’m pretty new with lasers and still testing materials to find out speeds and power.
I want to cut/engrave paper and on my tests there’s something weird going on.
If I use low power (so the laser does not cut through) circles are not complete.
I tried to set the laser to constant power but no change.
The problem seems to get worse with speed and it desappears after increasing power to 30%.
Can you confirm that the laser was still in operation at those circles? Or was it turned off at that locations? If you already used constant power (that was my first idea), then I could think of a connection issue at the laser module which happens at fast movement changes.
Here is a guide on how to check mechanics and another one on settings:
