lightburn shows full circles in preview until you “play” and then they are half circles. HELP!
Please post some pictures of the results so we can see what’s going on.
Would you be willing to speculate if the half-circle is caused by missing half the motion or missing half of the laser-on time?
Mine is doing the same. It shows a full circle the cuts an oblong circle. Any suggestions?
is an oval or engraves only half? cause if is oval you must check for stepmm, in LB in edit-machine settings you can find “calibrate axis”
It offsets 1/2 of the circle. I cut a square, it came out perfect.
