Hello! I’ve set up a post with all the info I’ve gathered on using the Gweike Cloud with Lightburn here:
I have a feeling that maybe your set-up could be different to my above and perhaps it’s not homing correctly after each job, so it’s out of focus when you go to cut again. If you have some pics of the results you’re getting I might be able to say with more certainty, but you could also check to see if you’re using the same set up as what I lay out in that post.
