Ortur LM3 20W, just received and first test
what I give and what is print
I try it with LaserGrbl the same test and is ok
any tips please?
Probably an illegal copy of LightBurn.
trial latest version
Did you download your version from LightBurn directly or did you get it with the machine? Unfortunately, we have seen it a few times that invalid LB versions are distributed with machines. Can you show us a screenshot from Laser Grbl with the same problem you mentioned in your entry post?
it was downloaded from original site, from Ortur factory I understand is need it some adjust in settings, now I’m not beside machine…
but Laser Grbl running from first try, without special adjustments
Download the program directly from LightBurn and try again.
I also am using an Ortur LM3 20W.
Ortur provides a free app called “Inspiraesth”. For more advanced functions, they recommend LaserGRBL or LightBurn.
However, they do not provide either of these with the machines or via their website. They direct you to LightBurn’s website to download.
Thank you Seth for help,
in the mean time I found it also
now just need to try it
anyway, LightBurn have almost all what we need
was incorrect software indeed, now all is ok
I assume my mistakes…
