Increase Fiber Rotary Field Size/Work Area
Hey guys, I’m using Lightburn with a fiber laser that Lightburn has it setup for a 195.7x195.7 field size/work area. This is what it changes to when I upload my cor file.
The issue is when trying to do a full wrap design on rotary I can’t because the field size is not large enough so Lightburn says hey, I’m not engraving that.
If I manually change my field size the design comes out distorted probably because the field size and cor file don’t match up.
Any suggestions on how to increase my work area in Lightburn without causing distortion or stretching? I need about a 350mm area to work in for rotary using the 175mm lens.
