When using the line tool in lightburn is it possible to increase the thickness of the line?
Tia
If you mean the output line, the engraved line, then I’ll bring my laser out of focus until the thickness fits the task. If you mean the construction lines you have the option of using the offset function with very small intervals, the result will also be displayed in output, the problem is just that the engraving time is multiplied by the number of intervals.
There are two more ways to make a thicker line.
The easy way is to draw a box vs a line. Set the height to the thickness you want and set the layer to fill.
The other way is to draw the line as normal then use the Offset tool to make it as thick as desired. Delete the original line and Bob’s your uncle.
