Inherit Material Library Description to Cuts/Layer
If I assign a setting from the Library e.g.
  • Material Name: “Cardboard”
  • Thickness: “1,5mm”
  • Description: “Cut Large Objects”
to a Layer, I will miss all this informations (Cardboard / 1,5mm / Cut Large Objects) in the Cuts/Layers Window. Is there a possibility to inherit at least the description to the Cuts/Layers window?
Thanks a lot for hints
Norbert
