tutorial covers pretty much everything you need to know to setup the YRR including saving old configuration settings and creating new ones.
One thing I’ll emphasize is that you need to set your laser to use Start from current position after you’ve manually centered the laser on the rotary workpiece. LB and your controller has no idea where your laser is positioned since you can’t ‘home’ it in the usual way.
