Installing Lightburn without having a laser
I would like to purchase lightburn before I get my laser. Can I install lightburn and play around with it until I get my laser or does it only work if I have the laser
you can create a device manually and use it. the manual device created can accurately match the settings of your laser, or not…
https://lightburnsoftware.github.io/NewDocs/CreateManually.html
here is info specific to a thunder but the same principles will apply.
Lightburn is free for 1 month. If you don’t like it, then you can opt out. A really good philosophy. Nothing to lose, everything to gain.
I purchased LB before I got my laser.
We offer two things to help you. First, we provide a 30-day free trial to ensure LightBurn is right for you. Second, please review this (in fact, all documentation is worth review), Adding a Laser - LightBurn Software Documentation
If you are getting a XTool D1, as identified in your profile, select Grbl as the profile. I would also check the XTool’s website for further information about that gear.
