can you integrate a nesting function into the software? that would be very useful for me and maybe others too. I often use large sheets to cut out around 900x600mm. You can save a lot of material there. Then you wouldn’t have to constantly switch back and forth between programs. Would be great if that would be integrated.
Consider to use the search feature of the forum, with the term “nesting.” There’s far more useful information in the results than I could contribute. Nesting software is “challenging” to create, from what I’ve read. There are other factors in the messages returned from the search results that may be of value to you.
