Hi there -
I have a Chinese 50W blue and gray laser that I use with a rotary attachment.
Recently I have had some intermittent issues. I am able to run several jobs just fine and then randomly the laserhead will stop in the middle of the job, ruining the cup…however it is still firing and the control panel shows that the head is still moving back and forth.
Once the job runs through and thinks it is finished, the laserhead will not move using the arrows on the controller at that point.
If I turn it off and start over, same thing…several jobs fine and then randomly stops while still firing. The lights on the driver are green and then when the laserhead stops they are both red.
Additionally, my air assist motor has become very loud, and it just doesn’t sound right. Is there any chance that this could be causing the problem? I am assuming no, but just trying to provide as much information as I can.
Is there anything you can suggest for me to try to determine the problem? I ordered new drivers, but I don’t feel confident that is the actual issue (or only issue.)
Any advice would be greatly appreciated!
Thank you,
Katsie
