Intermittent controller screen lines and connection issue
I have a Ruida 6442G controller and a few weeks ago I started having random instances where the screen on the controller will be filled with random lines and non-responsive or when sending a file from Lightburn I would get the connection error notice. Hitting reset on the controller would clear the connection issue and a power cycle would clear the display. There is no predicting these issues. At times, it is after every job, at others, I can run multiple jobs for an hour or 2 before one of these issues appear. This has happened running files sent to the controller and stored there and also when run directly from Lightburn
The controller has only 1 or 2 files on it at a time. It is connected via dedicated ethernet. No issues for several years running the machine. I have 1 other Ruida controlled machine with no issues and several galvo machines, also with no issues.
I have a new controller (6445gt5) that should be here this week but am curious if there is anything to check to try and make sure these issues do not repeat and if there are any error logs or anything to find and look at before switching over?
That suggests a loose / failing cable between the display (“HMI” = Human Machine Interface) and the 6442 controller.
With the power off:
  • Unplug both ends of the cable
  • Check for bent / loose / misaligned pins
  • Ditto for wiring
  • Replug
If that improves the situation, call it a win. :slight_smile:
It is possible the 24 VDC power supply is failing, but that would also affect the stepper motor drivers. If the display goes toes-up again, look at the two LEDs on each stepper driver: no green LED or a lit / blinking red LED will indicate a problem.
If none of that seems to help, then it sure looks like a dying controller. :frowning:
I think @ednisley is :flexed_biceps:. In my view it appears to be a hardware failure, most likely in it’s console.
You might get away with a screen replacement, and not a controller replacement. The console is under stress anytime you deal with the console, the controller itself isn’t.
:grinning_cat:
