Interval test air assist?
What layer does the interval test use? I understand that you set the speed and power in the setup but it appears that the interval test turns on the air solenoid, which I wouldn’t think that you would want on during engraving other than just to keep the lens clean??
It actually creates one from scratch internally, not based off any existing layer, and air assist is on by default for exactly the reason you mentioned.
