IP Camera issues since 2.0 update
I have not been able to use my ip camera since the 2.0 update. I was hopping a patch would come out but I don’t see any of this listed in the notes. I have tried downgrading to 1.7 again but it still does not reappear even if I reinstall the IP cam software or LB.
Would love some help as this has put a halt to my work for weeks. workstation on the 2nd floor and cam and laser on 1st floor.
Thank you
Thomas
LightBurn 2.0.00+ brings an entirely new camera stack to LightBurn, which probably is incompatible with your prior IP camera workaround (because it has yet to be natively supported in LightBurn) - you can try switching back to a prior version of LightBurn from here at any time: Index of /LightBurn/Release/
The forthcoming LightBurn 2.1.xx will have expanded http and IP camera support, but it didn’t make it into 2.0.xx.
Thanks @Colin, as listed above I tried 1.7 but it no longer works. I don’t know if 2.0 changed some files and even after a uninstall something isn’t fully removed and not allowing it to show up.
It’s possible that you may need to go into ‘Edit > Settings’ and change that camera capture system between Custom and Default when moving back to 1.7.xx
That did the trick, Thank you Colin!
Whats the estimate on the 2.1 release?
Thomas
We are unable to provide timelines for releases - they come out when they’re deemed ready :slight_smile:
