IPG laser and JCZ board
Hello
Has anyone hooked up an ipg or jenoptik laser to a JCZ board?
They have a 50 pin connector. like wide scsi if you know what that is :slight_smile:
I have a number of the ipg units and one jenoptik and just curious if others have done this and have wiring diagrams.
Thanks
Mike
Which JCZ board to you have?
Most of these sources appear to be plug compatible, at least signal wise. I’d try and hunt down a technical manual for the ipg or jenoptik. As far as I know there are a lot of fiber machines around with ipg sources. They are in the expensive range, so most go with the next best.
I do have a JPT manual for a source.
Let us know how it works out.
Good luck
